Another bike is born.....
Totally Farkled out!!
One of the most I've seen "out of the box"
Fricking nice!
Now I know why you spent what you did. The thirty year wait was worth it. Great looking bike!!
Did you get it that way directly from Italy?
D.
no. us beta has the byob program... order it with what you
want on it, and they set it up that way in paso robles, calif.
they take off all the stuff you don't want, put on all the stuff
you do want, and take all your milk money away to do it.
some of the stuff that is smog related, they can't change,
so they put it in the box, and you do it.
here's what went on this one that wasn't stock:
1 2014 Beta 520 RS 4-Stroke
1 Michelin Heavy Duty Tube 18"
1 Michelin Heavy Duty Tube 21"
1 Dunlop D606 Dual Sport Tire 90/90x21
1 Dunlop D606 Dual Sport Tire 130/90x18
1 Dirt Tricks Chrome-Moly Sprocket 48 Tooth
1 EK X-Ring Chain, Red
1 .52kg Front Fork Springs (221-239lbs)
1 Fork Bleeders, Red
1 Fox RC3 Performance Shock/W 5.8kg Spring
1 IMS Oversized Tank Dry-Break, Black
1 Dry Break Adaptor
1 Soft Seat Foam, Std Height
1 Wheel Set, Black Rim, Billet Red Hub, 21"Front, 18"Rear 1 Black Spoke Nipples
1 A-60 Rim Upgrade
1 Flag Style Handguards, Red
1 Vented Heavy Duty Skid Plate
1 Renthal Kevlar 1/2 Waffle Grip, Natural
1 BRP Rubber Mounted Clamp W/Scott's Kit
1 Fastway Adjustable Linkage Guard
1 EarthX ETX12A Lithium Battery
1 Dual Sport Rear Rack
1 Factory Beta Wide Footpegs
1 Rekluse EXP Auto Clutch
1 Supercool Radiators
1 Carb Vent Filter
1 R&D Flex-Jet Remote Fuel Screw Adjuster
1 Factory silicone Radiator Hose Kit, Red
1 Clutch Slave Cylinder Guard
1 Dual Map CDI/Switch Kit
1 Billet Flex Front Brake Lever
1 Billet Flex Clutch Lever
1 Rekluse Hand Brake Kit
1 Marzocchi 48mm Closed Cartridge Fork
1 Rear Axle Pull
1 Front Axle Pull
Fricking nice!
I must agree!  I thought mine had probably set records but you out did it!
That thing is AWESOME!
Without a doubt, the finest plated dirt bike I've ever ridden!!!!  Have fun with it!
Holy BYOB batman! Mines coming on Wednesday, too bad they didn't mix up our builds
Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
yep. required reading.
"watch a craftsman whose work is excellent, and you will see that he is following
no one path. the work to be done determines his actions, and his actions affect
the work to be done, until the work is perfect at the moment he is at peace."
apply liberally to everything you do. ;-)
  • Like 2
That is definitely the coolest looking 4-stroke I've seen. Have fun!
Did you let George ride it?
george let me ride it, eventually..... it's about there, the rekluse needs some
fiddling yet... it isn't uncoupling quite right.... he didn't want to snarf up the
rear knobbie before delivery, and was just thinking the clutch pack was wrung
tight and needed a little tweak to open it up... nope.. needs a bit of fiddling.
so i made some passes up and down the parking lot and blessed the knobbies,
but didn't loosen up the clutch pack.... this thing is gonna pull good.....
i'm turning over in my mind finding a new proud owner for the hayabusa, and
getting a set of supermoto DOT slicks for this.....
gear it really tall, and this thing would be wicked fun on ortega highway....
the 'busa won't bring all that much money, but i won't be tempted to go out
and get in trouble with it.... i don't need a 175 hp street bike with a lidar
detector, and danish lidar jamming... you turn on the ignition, and after the booting
up noises, a voice announces from under the seat "active countermeasures enabled"....
i think it's time reason took over.
Bike looks great,just need a new shirt.
you'll have to take that up with george, i'm not his fashion consultant.
it's pretty hard not to stand within 100' of the door to the shop and
not get some husky smeared on you.... at some point, the smithsonian
will come by and record for the permanent record, the last 40 years
of off road development in the US, one layer at a time. it's all there,
most all of it husky, however.
Wow, you went to town on the byob spreadsheet!  That is going to be an epic scoot!
...So the BYOB stuff is done in CA now? Didn't know that (not that it matters I guess).
Pretty sure my 2013 520RS BYOB was totally done in Italy.
...thought it made more sense to do the BYOB at the factory in Italy??? (guess not).
Nice bike btw.
