Metal broke by cam chain guide
Putting in new top end and cam chain. Took off flywheel and noticed a piece of aluminum was missing by front cam chain guide. You can see by the pics that the piece is whole. Not sure when it broke off. Dont see any damage. The cam chain guide still seats properly and does not move around. Should I be worried bout this?
I've never dealt with 4t black magic. But I know that the cases aren't hard to break on the thin bits like you've got there.
Could have happened when you broke the chain or dropped it possibly.
I don't know how to fix it. Sorry.
Its a cam chain replacement battle scar, but itll be fine. I wouldnt try reattachment. If the fix doesnt hold it can turn your motor into a paperweight.
Yea my old chain had kink in it. So guessing that had something to do with it. Wasnt going to try to fix it. Hope all will be ok. Thank yall
I wouldn't even think about the repair, unless you're going to take it apart and TIG. Otherwise, I think it will be fine without the repair.
You're fine it won't effect anything with the new chain. I would put a manual tensioner on it if it doesn't already have one. :thumbsup:
Alrite. Thanks
Sure as hek aint doin that
I would be more worried about how it happened
Again..I think either happened when chain got kinked during rebuild or happen at some point during rebuild. The piece was still intact so cant see that it happened before.
Oh ok, I could see it happening if the chain got kinda jumbled up down around the crank and when you tried to take of the flywheel it just put a lot of pressure there and broke it off maybe?
Edited by Bazuka Joe
