Oil leaking from starter gear cover
So I just changed out my stator and after re assembling I'm now slowly weeping oil out if the bottom of the cover the oring was good when I put it back on why would it be doing this?
Alright thanks a lot I'll check it when I get a chance
Don't buy oem. They want like $20 for that o ring. This is the one that fits. 10 cents with $5 shipping. I would do hyperlink but I'm on mobile. I ordered a few sizes when I was in the same spot because nobody knew of an alternative to the OEM.
http://www.theoringstore.com/index.php?main_page=product_info&cPath=367_23_24&products_id=1166
From my quoted post, the o-ring you require is
BS 1806 size ref 148 (69.52 ID 2.62mm section dia)
Dunno if BS (Bristish Standard) O-rings are available in the USA
The size of the Starter clutch cover O-Ring groove is 69.70mm dia
You want a little bit of stretch on the O-Ring when fitted (hence the 69.52 of the above O-Ring), and you want something close to 2.5mm dia in order to get the sqaush on it to make it seal
The OE Suzuki O-ring is very soft
Very likely you will get a std 70 shore hardness O-ring off the shelf, so it makes it hard to re-fit the cover
I now use the 3 screws and gradually tighten them down evenly to push the cover into the housing
I pinched the O-ring myself when I reinstalled the cover. I found the o-rings that come with the oil filters for the GM 2.2 fit perfect. Just an idea if you want to pick one locally.
