piston size and bore size
Theres different letters for pistons actually. On modern bikes theres a marking on the cylinder. The service manual will tell u where the markings are, then u order according to that.  If you really must have a serious answer.
If your bore is 54.5mm, then it's either been sleeved and bored, or it's beyond worn out, or someone doesn't know how to measure a cylinder.
The CR125 has had a 54mm bore since 1985.
If you go OEM, Honda only offers one size for replacements. The same goes for any aftermarket pistons, Vertex, Pro-X...
Wiseco offers a 54, 54.5, 55, and 56mm piston for the CR125.
