Hole in case?
2002 yz125 and I found This perfectly drilled hole by the looks of it I have never noticed it before it DOESNT LEAK but still what would have done that I had a skid plate on
[qu ote name=Tro1086" post="11629333" timestamp="1400989556]Is it around the water pump? Looks like the weep hole for the water pump.
It's on the clutch case not the crank case and right in line with the water pump
Sounds like you found your weep hole. It will leak coolant to let you know if the water pump seal is leaking. Similar to a car.
A picture from a little farther away might help, too.
