Crf450x ticking noise
Recently my crf450x has been making a ticking noise from the head, it is also getting hard to start, from cold it will take a fair while to get going, but once its warm it usually starts within a few kicks! I was thinking it cld have somthing to do with the rocker arm? Any ideas as to wat it could be, the ticking is driving me nuts!
Hard to start cold,  but easy to start hot, is usually a sign of a leaking or out of adjustment intake valve.
Check your valve clearances
If you have some real hours on the motor, it's probably time for a head rebuild, and a change to SS intake valves
Ill have to check the clearances when i get time in the next few days and see whats going on! I think im gonna have to change to stainless valves tho!
Every few rides i gotta keep topping up the oil aswell, cld that have anything to do with the head aswell?
Probably more to do with worn piston rings.
Time to do a top end, get the stainless valves and a new piston.
