Honda Tire rubbing/rim size question
I was looking into buying rims for our Honda foreman 500 4x4 and I found a cheap barely used set that are 12x7's for all four rims. The stock rims for this atv are 12x6 and rears are 12x7.5. The bolt pattern is correct but I am worried that the front tires will rub when you turn all the way left or all the way right. Will an inch make a difference? And is there a need for the rears to be wider that the fronts? Also, could I pull off using the same tires that are on the oem rims on the new set or will I need to buy all new tires as well?
