Air filter mode
I took the air filter restriction cage out. I am talking about that metal cage that is need incase of a backfire.
Does that mode make the bike run leaner or richer. Do I have to go down or up on jettings.?
Edited by carmelo1970
I would like to know because I have a esitation or bog when in under load I open up the throttle it sound the same thing when running out of gas. I am running a jd jettings with 182 and blu needle at 4* position click.
I would say mid range. For example up hill or if the rmps are a little low . But as far as throttle position is from a little over 1/4 throttle to 3/4 but after couple seconds it clears up and only sometimes if I continue to open the throttle it wants to shut down and id I go back a little with throttle it goes fine
