tank change
Hi is it possible to fit a tank from a Drz 400 e to a Drz 400 s
if so how easy/hard is it as i can see they have different fitting
I am thinking the tank from the E would be better as i have already put a large dent in my tank
thank in advance  :thumbsup:
Sure if your handy with metal working tools and a welder. You'll have to make up some front mounts and weld them on to the frame. The rear rubber band mount should be easy. We just did the opposent and put an S tank on an E so it could be painted.
Just buy the parts you need fron the thumpertalk oem shop, easy, thats what I did, no fabrication required.
