yz 125 side cover
my side cover has cracked so i bought a new and am in the process of transferring the clutch cover and i noticed the two little pin..how do i remove them to put them in the new cover?and also i took all the bolts holding the water pump cover off but it seems stuck,,how do i get that off also?it seems like the gasket or something is holding it on..i havent taken any of the propelller etc off the old one yet just trying to remove the cover first..its an 01 125
Any guide/locator pins in the covers are pressed into place and should come out with a tug from a good set of pliers or vice grips.  Be careful not to mar the pins.
With all bolts removed from water pump housing, give it a tap from front or back with a rubber mallet or soft dead blow hammer.
Don't forget to disconnect the power valve actuator from the cylinder before you remove the cover.
