crankshaft installer
Does anyone know the part numbers for the special tools to install the crank on the drz 400s?  My 2001 drz400e factory service manual gives the part number for the installer (09910-32812) and an attachment (09940-52861).  The attachment cannot be the right number because that is a fork seal driver.  Even the pages in the back of the book that lists all special tools for the bike doesn't list any attachment to install the crank.
You don't need an 'installer' to put it back together
Insert LH main in to case (warm case so bearing drops in) - do same with RH side
Warm bearing to expand the inner race and drop crank in
When ready to assemble RH crankcase, just warm the bearing again and drop the case on
Easy - done 3 like this with no problems
As always there are many ways to do the task
Some right
Some that work most times
And some that are just a bad idea
Using a crank puller is never a bad idea and falls in the done right category
Heating the case to expand and freezing the bearings works most times just fine.....Until it doesn't then you need the right tool
The tusk crank puller is a nice light duty tool that works as advertised
