Runs only with choke on?
Just got a 05 ttr230...wouldnt even try to start when i first got it, but after i cleaned the carb it acted like it wanted to....for me to get it running i have to pull the choke and take the seat off and hold my hand over the intake, and crank it untill it starts....once i get it running a while, i can turn it off and crank it back up with no problem...but the choke has to be out the whole time...any suggestions?  P/s-even when i get it warmed up once i go to push the choke in, it cuts off immediately
Edited by dirtbreed
Carburetor pilot jet and passages still plugged-up in my first guess.
Same here, but the ttrs are cold natured so they have to have choke on for a while before warming up
Took the pilot jet out and everything looks clean...push air threw the air intake port and got air comming out the pilot jet port and visa versa..how can u tell if you need a new pilot port?
How about where the fuel exits the pilot jet and into the venturi?
How's the fuel screw area looking?
I would just get a new pilot jet, they are not expensive. Plus, they are finicky beasts and sometimes just a small amount of gas varnish can cause loads of problems like you describe.
I have wasted hours on cleaning and re-installs only to end up simply buying a new one and problem was solved. :banghead:
Everything looks good to me....When look down where my pilot jet goes I can see into the venturi....pushed air into where the pilot jet would be and I'm getting air threw my main jet
Report back with results.
Don't fall off the edge of the Earth like most guys do when asking for help.
Ordering the #38 pilot jet and #130 main jet this friday...While I'm waiting for that, I'm Goin to remove the plug on my carb so I can to the pilot mixture screw
Got the #38 pilot jet in today...so today I installed it and removed the plug to the pilot mix pin...and adjusted it to 1.0 turns out....I can now idle without the choke...I would like to thank Yzetc and chaconne, really appreciate the help and looking forward to future help...thanks guys
Most excellent happy riding. :ride:
you don't still happen to have those part numbers for the jets? I bought mine and the pilot #38 was too big. mine is a 2012 ttr230 and is doing the same after 30 min or so is heavy overheating and dyeing I also have a very loud ticking noise I think that the valves are outa spec but what my service Manuel shows on my bike and whats actually on my bike don't line up
#38 jet Yamaha part number 43f-14342-19 and for a #130 main jet Yamaha part number 288143436500
Edited by dirtbreed
so I changed the jets today bike rides amazing but even after valve adjustments I get a loud ticking when I hit the throttle even lightly
