Compatibility Question 2003 450 MXC
Hello! I have a 2003 MXC that is need of a crankshaft. I have read quite a bit about the differences in models. Everything I came across seems to indicate the differences are mainly in transmission, suspensions, accessories.. things like that, with the main engine components being the same. With that in mind, my question is would a crankshaft from an 03 sx-f or an 03 sx work?
Thanks in advance
Steve T
As far as I know any 450/520/525 MXC/EXC crank will work.  Note that the 450 SX crank has a shorter stroke than the 450 MXC crank.
Ok, thanks! I wanted to be sure before I stuck everything together and it had to come back a part.
Steve T
