Which seal is bad with milky trans oil?
sounds like the water pump seal to me.  But if your going to put a new seal in, I recommend putting in a new shaft and bearing also, Over time the shaft will get a groove in it and will still leak, same with the bearing over time the bearing will wear out and get some play in it, if thats the case it will take out the seals every time because the shaft will be moving around in there.. but its a Pretty easy fix.
