Which seal is bad with milky trans oil?
I've done some reading and it seems there is an inner and outer water pump seal. Is the outer accessible by only removing the water pump cover or do you have to take the side case off to replace it? I would like to do it one step at a time to avoid the expense and extra work, plus I gotta get a service manual before I really tear into it anyway.
What year is your bike? The last time we replaced mine we took the whole right crank case off. You might be able to do it without taking it off. What I have learned in mechanics is dont take short cuts because it usually comes back to bit you!
