no fuel pump pressure
i bought a 2010 crf450 and it is hard to start. i hooked a 12volt battery in place of the condensor and the pump came on. fuel came out, so i hooked up the fuel line and then it wouldnt work again.the pump is good because i took it out and tested the pump. could the cdi be bad causing this? also when the cdi is plugged in my battery voltage drops. i am using a 12 volt lantern battery, i have 12 volts but ,maybe not enough amps any help will be appreciated. this is driving me crazy
