2009 RMZ 450 Problem
Hey Guys
I got my 2009 RMZ 450 about 3 months ago
Perfect condition
Has run perfect until Monday,It started to hestitate and cough whenever I hit bigger bumps
or whoops
Get it home and It starts and runs perfect on the stand,took it back to the track and it did it again
I can practice starts and its great,first bump and its back to coughing and shutting off
I checked all the plug wire connections,pulled the fuel pump to check the wires were tight
I checked the plug,plenty of spark
Any ideas? this is driving me crazy
Clean air filter,new gas
1. Disconnect your kill switch and see if it continues.
2. Check you plug boot to make sure it is tight.
3. apply dielectric grease to all your connections.
If all of those fail... you need to look over all of your wires to make sure none have any rubs. A lot of times the wires rub through and contact when vibrations are excessive.
I had a similar problem and it was my mixture screw rattling out. I put the factory one back in and it solved the problem. Bdub is pretty sharp so I would go with his suggestion too.
2009 is FI. No mix screw
Found the problem
Bdubb,you were right on
I took off the cdi box and on the back of the harness was rubbing and the white wire with blue stripe
was broke,right at the cdi box
The wire goes to the magneto
I guess its a new wiring harness for me
Thanks for all the advice
No problem... glad you found the problem, sorry it is an expensive one. Hopefully you can find one on eBay or something. The RMZ's seem pretty bad about that. I wrapped all of mine with electrical tape in all places that they come in contact with anything. Might be worth doing... only a few bucks for a few rolls of electrical tape.
  • 3 weeks later...
