kickstart stuck
has this happened to anyone. While trying to start the bike it kicked back pretty hard, then the kickstart got stuck all the way down at the bottom of the stroke on my next kick attempt. I pulled it up and it was stuck and wouldnt go down. I took it off the stand, rocked it back and forth in gear and it seamed to fix it. The bike has 12 hrs. On it and i just put a 270 b.b. Kit in it. Anyone have any clues. I pulled the r. Crankcase off and tore the top end back down to make sure everything was ok, everything looks great inside.
Edited by bryce716
Sounds like kick shaft isn't indexed correctly.  Did you make sure the punch mark on the starter ratchet was lined up with the one on the shift shaft when you put it back together?
