300 clutch problem
2014 300, when the clutch lever is pulled in all the way and shifted into gear the bike pulls forward a bit and the bike almost dies. Does anyone else have a similar problem and what can i do to fix it?
Does it do it all the time or just cold? My 14 will only do that if I haven't warmed it up at all. A lighter weight if oil could help too if you are running something real thick.
Mine does it too, just got the bike though 2006 and it has a brand new clutch basket and clutch plates so thinking it may just need to get run in - it also is fine when warmed up, just when it is cold or the first time or 2 I put it in gear is it like this.  I have also read that the aluminum clutch plates can warp a bit if they get hot and that will make the clutch not fully disengage.
Curious if anyone knows what it is also!
It does it all the time when it is hot or cold. I just bled the fluid and their was no air in the line.
