Crf 450 2010 Starting issue..
Hey
Wont start cold installed new inlet valves and all valve clearners is OK. Have to tear it behind the car before it stars
but when it starts the red light on kill switch starts plinking and stars on dime wen hot the issue was there before i checked valves.
Cleared the fuel filter and poked all connectors maybe i missed some i am out of ides what that might be. Don't  have the manual
to check what that plinking means if you have any ides please let me know thanks any help is welcome...
Thanks
You have an error code detected. What is the blink sequence in long and short blinks? There may be more than one sequence blinking.
It blinks continuously the blink is like half a second long and the light stays of to like half a second
Thanks
my2010 has a code after i put a new stator and condensor in it. i think mine is showing the map code it blinks 2 times after the light goes out when it is started. these fuel injected bikes can be a pain
Constant blink is prolly a sensor unplugged like ect or iat in the airbox
checked and cleaned both but no good if you have any idea what else might they be let me know. but yeah makes sense that continues blink might be something unplugged..
thanks
1 short blink. Is a MAP sensor circuit malfunction.
Its normal for the MIL to blink on start. There is a code detected if it keeps blinking while the engine is running.
Finally got it started and there is some kind of code the red light blinks seven times and then there is a pause about  three seconds and it blinks again
and keeps doing that continuously..
Thabks
7 blinks is an "ECT sensor circuit malfunction" the book says this will cause "hard start at a low temperature" . The ECT sensor is the one that goes into the cylinder head just below and to the right of the throttle body.
Edited by nzgsr
Thanks
I guess that what it is it starts terrible when cold ...
Cheers
