1992 dr350s banjo bolt oil leak help!
My bike started leaking oil really bad between the banjo bolt and clutch casing I have no clue why unless my oil pump is gone bad ? Replaced a bunch of parts still have issue what could it be
You replaced both crush washers? I read your other post now and with the new oil line two new crush washers that ought to do it. Don't overtighten.
Edited by bimbamboom
I was going to replace them when it cracked a oil line but I never touched the banjo bolt in the first place why would that start pushing oil out of it like it's over pressured
Or was it simply a case of old part worn out also I was kinda ridibg really hard when I noticed it started to leak
You said in another thread u stripped it... Was that after you noticed the leak? U posted a few times about this no?
Don't let Monday ruin your Sunday!
One was a double post and I broke one of the clutch basket cover bolts but got another one never stripped anything
