4th gear and crank shaft shredded
i have a yzf 250 2004 and i shredded 4th gear and the crank shaft got shredded any ideas on how it happened?
you'll find out when you tear the engine apart. it can be so many things. any answer will be speculation. Also not a whole lot of information on your post. I've heard of shredded belts, shredded meat, but never a crankshaft.
we already have and the mechanic thinks a bolt or bearing has given in and shredded everything because there was fine bits of metal every where
