Exhaust issue
there is nothing wrong with your bike, soot in the exhaust is completely normal, the reason you get soot on the outside is because your insert has a very slight leak.
remove the insert, check for warping\damage on the insert, clean of the surface of the exhaust and the insert and reassemble, use some high-temp silicone if it still doesn't seal properly.
