Burning anti-freeze in my CR125R
I've only taken it out a few times since I brought it but have to add a pint if anti-freeze before every ride. I'm fairly new to the two stroke game and appreciate any feed back.
You need a new head gasket possibly.
If you are burning a considerable amount of anti-freeze, you would see white smoke.
You either have a bad head gasket, or simply a hole somewhere in your coolant line.
Check your water pump to make sure that's not leaking it out as well.
Mostly coming out of the overflow when I first run it then slows down to just about nothing. I noticed today it was a little cloudy when I filled it.
If it's coming out of the overflow then that's simply boil over-
It's a way to level out any overfill that you have in there. Are you sure you are losing a lot? if you fill to the very top, its going to boil over and get rid of any excess. You only need enough antifreeze to cover the fins inside.
I am filling it to the top maybe I am just over filling it. It's all sound advice, thanks guys.
You are def overfilling then- and the runoff is 100% normal.
If it didn't run out, it would boil and cause so much pressure that you would pop the top right off.
