What bearings do I need?
I need to replace both of the orange bearings in this picture.
Would it be the main and crank bearing?
I need to know what to order.
The plan is to order Hotrod bearings unless you all think there are better bearings to get.
Those are your trans bearings for your main shaft and counter shaft. Go to partzilla.com and look them up by your year and model and order them from there.
Just wondering why do you think you need to order those two?
I really only need the main shaft but since I am splitting the cases might as well replace both.
The main shaft bearing is shot. Quite a bit of slop in it.
Should I just order OEM bearings or go with aftermarket?
If I am going through the trouble I might as well put the best in it.
I wouldnt order anything until youve got it completely apart. If youve got slop in the main shaft bearing, the transmission needs a really good check over.
