rm 125 head gasket keep blowin?
why do my gasket keep blowing? its the head gasket i guess cause its leak coolant from cylinder. its my second one so far. how and why do they blow? its an 02
are you sure you're using compression nuts on the head  not all nuts are created equal, i prefer the nuts with the grip pattern at the bottom for extra hold, also make sure when you torque down the head you torque the nuts in a criss cross pattern to equalize and even out the pressure as you torque the head down.
