hard to start hot
hi guys your help is needed again i finally got out to do some green lanes today for the first time had a fantastic day the only problem when i had a tumble ( quite a few ) the bike was really hard to get going again i tried using de comp still same what am i doing wrong
Try holding the decomp lever and hold the throttle wide open. Kick thru several times. Then, what I've found works best, release the decomp and kick from TDC and wick the throttle open at the bottom of the kick.
no i did'nt touch the throttie i will give it a go next time maybe i should go to the gym and work out the one leg
Oh, in case you didn't know, the XR needs to be kicked from TDC every time. If you try kicking the engine over at any place else in the stroke, its a wasted effort.
Ok thanks I am going to check valve clearance too been told they could be too tight
