Help: New Lithium Battery Not Cranking?
Hey guys,
I purchased a new WPS lithium battery to replace my weakening lead-acid battery.
After hooking it up, the lights & speedo turn on with the key in the on position, but when i press the start button I get nothing... no cranking at all.
I charged the battery on my battery tender fully before the install.
Any ideas on the reason for this?
Note: I reused the terminal nuts and bolts from my old battery since the bolts that came with the new battery were a bit too think to fit through one of the pair of leads that hook to the battery.
Edited by cbus
Its not the kill switch...
The headlight and speedo DO light up... jest no cranking.
I hooked up my old battery and its doing the same thing
Do you hear a click on the right side of the bike above the exhaust? If not, your starter solenoid is not activating. Take off the rear right panel and put touch a screwdriver across it to see if it cranks that way. It is a small box with two fat wires going to it. Touch the screwdriver to the big screws holding the wires, but only for a second.
+ 1 Sounds like a fuse.
Ugh.. Solved
Turns out this bike needs to have the clutch pulled in AND be in neutral to start.
Edited by cbus
  • Like 2
That's why both are disabled on my bike!
Ugh.. Solved
And it was not like that before you replaced the battery??? :facepalm:
  • Like 3
Ugh.. Solved
:facepalm: OMG................................ :bonk:
Come on mate....try a little thinking before you post a fix it thread..... :thinking:
Edited by Craigo 485sm
