klr600 hanging idle
idle hangs and also when riding/shifting the idle hangs. nothing is more lame than pulling in the clutch to shift and the engine speeds up.
i cleaned it, shimmed the needle and backed out my fuel screw 2.25 turns. sometimes it idles ok but most times and always when riding it hangs.
intake boot etc all good, .09 thou shim under needle
 the slide has visible wear, is this machine susceptible to a lean condition with a worn slide?
Edited by over rev
