Stage 1 intake cam, stock exhaust cam?
Does anyone have experience this? What is there to learn about this setup? Is there any adjustments that need to be made to the stage 1 intake cam so that it can work well with the stock exhaust cam?
That setup will work fine. If you have an E exhaust cam, you probably would never notice a difference by changing to a HC exhaust cam.
If I am using the stock model s exhaust cam and the stage 1 intake cam do I need to adjust the stage 1 cam?
Which stage I cam?
2003-1IN
2047-1IN
2251-1IN
Reason I ask is any of them can be used with the stock exhaust cam, and the 2047-1IN and the 2252-2IN have the same profile.
Just wondering, is there some benefit to just running a stage 1 intake cam with the stock exhaust cam?
I should probably use the search function, but figure OP asked about the setup.  Just wondering why?
Stage 1 Intake should give you more low end, stage 1 exhaust gives you more mid and top end and ever so slightly takes away low end (un-noticeable).  I did stage 1 exhaust and stock intake together, looking for more mid and top - didn't even have to adjust shims!  It was perfect and valve specs are still good 10,000 miles later.  Throw engine assembly lube all over that new cam and bolt it in - an hour or two job.
