Screeching/grinding
so I had this same issue. on mine it sounded like it was coming from the case but it was actually coming from the top end. I was given the wrong oil filter at the shop so when I installed oil wasn't getting up to the top end. if you want to check it next to the intake valve cover I believe its on right side if your sitting on bike is a random looking bolt almost facing the back of the bike. take that bolt out and start up the bike wait about 30 seconds or so and oil should dump out of the bolt's hole if it does then your good it doesn't  by replacing your oil filter.
