VERY difficult time trying to get 4strokeworks header on
I've had it for about 8 years. Took it off to sand it and spray with high temp black paint. For the life of me, I cannot get this mofo on.
I didn't spray the end that goes in the exhaust port. I don't remember ANY problems putting it on when I got it in 2005.
Any suggestions would be appreciated.
2005 Kawi KXL300
Edited by goldensaber88
No.  Only the one at '2 'o clock'. After I make the gasket, put that in, I'm going to dremel just a little bit on the flange holes. Hopefully that will do it.
If it was on with modifications and all you did was remove and paint it and put it back on it shouldn't need anything to put it on. Mine was right but I kept it loose from the pipe to get it all lined up.
If I remember my gasket right it was a two sided metallic ring with a compressible material sandwiched in the middle. It is pretty important to have a no leak connection.
