Crf 250r rod play?!
Radial play (up and down) just .002"  at the big end and  .030" between the rod and crank wheel. These are the max.
Yes you should have zero up and down play but some lateral play is normal. I looked in my book for the tolerance but haven't found it yet, I will post back if I do.
Edit: bucket beat me to it.
Edited by mdwsr
Hey, just getting you back for the last one.  Ha,Ha.
The crank can be intolerance and still be bad the cages wear firt and then the crank goes if it has near 100 hours and its a part rebuild it or replace it .
Thanks guys , cranks fine , took the head off and cylinder and piston and cylinder was good , bur ill post some pics of the head , and tell me if i need new seats!?ImageUploadedByThumper Talk1401660928.423861.jpg , where the screw driver is there is chinks missing , as well on the other intake valve
