jetting issues/hesitation
I'm having issues with my sm. It hesitates at around half throttle when cruising at around 60mph, happens in every gear but have been testing on a long straight road in 5th.
Here is the spec
dynojet kit 3110
#25 pilot
extended fuel screw 3 turns
2nd groove on needle
155 main jet
3x3
Fmf header and can
k&n filter
I changed the needle to 3 groove (middle) and it raised the hesitation point to 70mph. Do I raise it again? Or is there something else I need to change?
This is my first time jetting a bike and it seems to run well on low or full throttle, just cruising is the issue.
thanks in advance
Tried it without the airbox cover and it made things worse. Massive hesitation between 60-80mph on 1/2 - 3/4 throttle cruising
any ideas?
any ideas?
Re install side cover..
Now partly cover your 3x3 hole with tape.....Cover it by 1/3 , leaving 2/3 open....
Test ride under same running conditions.
Better or worse?
Edited by Craigo 485sm
