Adjust clutch lever for engagement?
I'm looking to set up my clutch lever so that I can hold on to the bars with my middle, ring and pinky fingers, only using my index finger to actuate the clutch. Right now, I need to lift all of my fingers off of the bar and onto the clutch lever because the clutch doesn't fully engage until the lever makes contact with my grip. Do I simply adjust the cable to be shorter?
Yep, that simple! ;) Also, you can get yourself adjustable pivot levers.
By putting (a bit of) tension on the clutch cable, it takes less pull on the clutch lever to disengage the clutch. Therefore, the moment where it disengages will happen with the lever further away from your handlebars.
Edited by Paul_
