Breaking in new transmission bearings?
Hi guys,
I just did a complete overhaul of my lower end I replaced every bearing in both cases with all oem components (gaskets, seals collars etc.)
Anyway my question Is I know about breaking in crank/crank bearings but is there something I should do for the trans bearings ? Like load them is all gears gradually, replace oil after first run?
Thanks for the replies.
You don´t need to run in bearings. You need to run in a piston if you fancy doing it. But bearings? No.
