Is a 2006 yz 250f a green sticker?
Is a 2006 yz 250f a green or red sticker? I found one near me and I was curious what sticker it would have?
I don't have much of a clue about cali but from what i have read anything after the early 2000 year is red.
If I'm wrong consider it a bump
It's not green, too much noise and pollution problems, only technically for closed course use. The wr 250f is basically the same bike but gets the green sticker then u can pay 50 bucks and buy the kit to turn it into the yz more or less
Red sticker.  2002 was the last year of the green sticker YZ's.  If you have to have a green sticker I suggest you go with a WR250 or a CRF250X or a KTM.
Wow is that wrong
The motor and the suspension are completely different are would require about $1500 to get about 70% of the way there.
Any bike with a number plate and not a headlight, from 2003 on, is RED sticker.
Motocross bikes 2003+ RED :devil: , Motocross bikes 2002- GREEN :D  Enduros are usually still GREEN :D
Wow is that wrong
I was referring to the aftermarket gytr kit that I do not know the exact price of without looking up but I assure you it's at most 150 bucks. It's the one that has the shorter throttle stop screw, modified and plugged up ais system, different jets for the carb, remove some of the choked up silencer parts etc... But u are right the more will always lug lower on the wr and the suspension will be softer and it will be heavier for various other reasons, kick stand, headlight taillight, computer and electric start etc, but they are built on the same frame n everything just depends what your going for
Still 100% wrong!
They don't even share the same frame, they just look the same!
Carb
Head
Exhaust cam
Intake cam
Crank
Both inner cases
Stator flywheel
Header
Pipe
Shock
Forks
CDI
Harness
Subframe
Seat
Tank
Shrouds
...and about 45 other parts...
...are different on the YZ
Edited by TheKoolAidMadeMeSick
Just be an out of state &%$#@! like me! Long as I still carry that old Illinois drives license I have all green sticker bikes.
