DRZ 400s speedometer not working
I recently bought a 2004 drz400s with a non working speedo. The backlight turns on but no numbers show up...nothing..just the light. Can anyone help?
If you are good at taking stuff apart then open it up and look for corrosion inside from water.  I found a corroded tracing in mine and was able to repair it.
A local electronics repair shop may be able to help if you lack the skills.  FAK  $800 for a used speedo?
The Vapor also has rpm readout.
