01 RM250 crankshaft rebuild
Anyone know if there is a complete crank available for the 01 RM250? All I can find are rod rebuild kits. I would mush rather use a complete crank assembly if one is available.
I have not run across a complete crank replacement from the aftermarket companies for the 01.  You have to rebuild what you got.
You can always purchase an OEM crank Shaft Assembly. They are about $600 but I bet you could call a couple of the shops and usually they can lower the price a bit. I talked down my local shop from 300 to 255 on a yz crank shaft. Maybe give that a shot.
http://www.rockymountainatvmc.com/oem-schematic/4#
This will take you to the oem Crank Shaft assembly for your bike. it is part #6.
