A 110/100 x18 tire vs 100/100x18?
I think I know the answer but I figured I would get your thoughts. My CRF runs 100/100x18 tires spec.... No harm in putting a 110/100 tire on there right? I know it is a little wider... I primarily ride woods/single track.
Should be no problem. Just take a look at clearance between tire side knobs and swingarm currently to see if an extra 5mm per side would be a problem.
Then again, one tire manufacturers 110 is not the same as others. Which make, type tires are you talking about?
Example, I replaced my stock Dunlop rear 110 mx51 with Michelins S12 and had to get the 130 for it to be equivalent to the Dunlop 110.
Edited by Trailryder42
Tire sizes don't run true to actual specs. One man'f's 100 is the same as someone else's 110. not a big enough difference to be concerned with.
