Rm125 Tranny
I took my cylinder off the bottom end and antifreeze poured into my bottom end. I changed the oil and nothing came out, and every time I wipe antifreeze off the crank, and kick it over there is more on it. What should I do? Is it bad for my crank/gears??!
It's not the best thing for the crank but it can't get to your gear box. You need to pull it out of the frame and turn it upside down to get it out. Then put some premix oil on the bearings.
