yz125 water pump leak
I was in the process of putting my water pump back on and I lost those two pegs..anyways input the covet back on just to see if it would make a difference..now it leaks from the bottom..is that because of that..I also installed a new seal..now should the ring be facing The cover or facing inward??the manual didn't show that
IIRC the ring faces the cover. Just check a  schematic. And yes, those dowels are there for a reason. They are cheap so order them. Torque the bolts correctly and there should be no leakage, provided you used a new gasket and cleaned up the surface.
