01 yz 250 rear linkage question/help please?
So I pulled out the old swing arm and rear linkage bearings as well lower shock,reinstalled with all balls and bearing connection,pretty much all back together now but I'm noticing on the triangle and linkage arm,even lower shock there is side to side play if I take pressure off of swing arm.i hadn't notice this extra space before wasn't sure if I just never noticed or has something gone wrong?
So on the lower shock the side with the gap and I can move it side to side.as well the same with the triangle.i know the collars make a distance so it cannot be so tight it won't move but is this too much?
So when everything is torqued back,it should self align or just out riding it self aligns,because I can move them back and forth but I referenced my Manuel and everything should be back together the way it came apart,triple checked it.
