2007 TTR 125 Gearing Questions
So my buddy just picked up a 2007 TTR 125 and i am helping him get it back into shape. Everything is running perfectly after i performed all of the needed scheduled maintenance, but im pretty unhappy with the gearing.
When i start out in first gear i can only do like 1 mph and it seems so short it is unnecessary, and when i get to 5th gear i constantly find myself reaching for another gear. Is this problem something that a new rear sprocket will fix? Ive done a little research about sprockets and it seems like changing out the front sprocket might be too much of a headache (needing to grind down the casing to get it to fit). I know it is only 125cc so i want to make sure that the bike doesn't lose all of its get up and go.
what are the sprocket sizes?
13/49 is stock IIRC and work well for the 125L.
I believe that they are stock front and rear.
Tomorrow i am taking the wheel in to get a new tire, i will count the teeth then and find out. if it is stock how many teeth should i go down?
I just counted them last night and it turns out that the rear is 54 teeth. It does look very stock though. Any thoughts or suggestions?
13/54, stock for the L, my mistake, 13/49 is the small wheel.
If you don't like stock because its low (slower), then depending on availability and fit, you have only 1 choice, since your research found larger front requires grinding, not something I would do either, is a smaller rear sprocket.
1 tooth on the front =  about 3 on the rear, either of which make quite a difference.
so sounds like you're going to look for a 50-51 rear sprocket as your 1st experiment.
Usually the stock sprockets on TTR type trail bikes are optimal for most who buy and ride them thou.
Thanks for the advice on how far to go. Time to start shopping for new sprockets!
I've got a 2005 large wheel. I had the same problem as you as I do a lot of longer distance off road cruising. I changed to a 13 front and 49 rear. Made quite a bit of difference in top gear without impacting much on the lower gears, which is good for tricky bits! You will need to shorten the standard chain length though - just a caution!
Edited by Joshua Macbeth
