XR400 Rear Hubs That Fit
Hey all,
I sent my rear hub to Bykas to have a Fat Paddle tired assembly added and it looks like its not as easy of a project for them.  I guess the XR400 stock hub has 2 different lengths of spokes for each side of the rim which causes problem with their current set up.  So my question is...
Does anyone know of another bike's rear wheel assembly that will fit an XR400 but also has the same length of spokes for both sides?
Thanks in advance.
Talon make a rear wheel to suit the XR4 with even size spoke length but im not sure if it has the same amount of spoke holes as a standard XR4. I have one on one of my XR4's, i'll check it this afternoon.
Unfortunately it was already on the bike when I got it. I guess you could contact talon directly to find out a model/part number & go from there.
Found a Talon hub for an XR400 here:
http://www.ksrwheels.net/productcart/pc/viewPrd.asp?idcategory=222&idproduct=588
Seems a bit pricey but luckily I've been saving up a bit.  Doesn't use the funky stock spoke set up, all spokes are the same length so this should work.
Edited by Foxmann250
