95 yz 125 cylinder question?
There should be just one holes coming out of the cylinder by the power valve it is nothing more the a bleed off system since premix lubricates the powervalve. This hose bleeds off the excess oil build up and in theory is supposed to help keep it from geting to much carbon build up which should help keep the power valve free to move. You could block it off if you really want to power valve doesn't really care.
Thank u. Thats what I was thinking. But mine has two I will have to take a pic. But thatnk u for info
Any body know if there is any differences between 95 cylinder and 97 cylinder other then the power valves? Basically I want to kbow if the 95 cylinder would work on the 97 motor?
