ktm belleville spring
Hi i have a 2014 husqvarna te300 which has the exact same engine as the ktm 300xc 2014. I have a question about my clutch. I took off the clutch cover and when I pull in the lever to about half way one side of the basket comes up leaving the other side down, then when the lever is all the way in the other side slightly moves out but not even close to the other side. I think it is a defective belleville spring. The bike is brand new and has only 20 hours of use and it has always pulled forward quite a bit when in gear and the clutch lever is all the way to the bar. So is it even possible to have gotten a deffective belleville spring? Is there suppost to be even pressure from the spring?
