speedo magnetic signal
Hi, I have this Yamaha XT125 2007 model with a destroyed digital dashboard unit. I am fitting an alternative unit. The problem is the new unit has 2 wire signal input but the sensor unit already on the bike has a 3 wire output. Also the pick up sits high up on the brake disc but I can not see any magnet fitted. So is there anyone out there that knows how the standard xt125 works? I am hopeing to use the existing sender unit into the new digital display (Acewell) unit.
Further to this one. The original set up with the sensor on the fork leg and directed to the brake disc. The end of the
sensor is magnetic and there is no magnet on the wheel as it rotates. All the sensor can see are the slots in the
brake disc. So is it counting the slots instead of counting a magnet passing? Anyone know?
