Ktm lc4 540 conversion to 620 is it possible
I have a ktm 540 dirt bike I did think it was a 620 but it only has a 95 mm piston how hard would it be to convert up to a 620 as I have a fair few parts from a 620 already thanks.
Should ask a shop.
But I believe if bottom end is the same , then just a cylinder piston and timing chain.
I think the stoke is the same as the barrels are the same height side by side
I believe that it should work.
A couple years, you could take a 400 all the way to a 525 & beyond with some machining.
Yes I took the head off the 540 and it's cracked and have the whole top end off a 620 so it's worth a go and the bike will be better at the end :)
Post up some pics of the how to as you go.
Would be a good thread.
