? removing oil injector on Pw50
It's a 06 I bought the block off plate but don't know how to get the gear out or rod to put the plate on. Anyone know?????
You may have noticed that no one has responded because it's a bad idea. You're just creating a headache for yourself. Oil injection works flawlessly for the life of the bike, uses no measurable power and requires almost no maintenence. No reason to mess with it.
Put the oil injection hose back in place and kick the bike over. It should have enough lube for the minute or two that it runs without the injection prime to fix itself. If you're really concerned, empty the gas tank, put about 1 cup of 20:1 premix in and start the bike, let it run till it starts obviously smoking. Then refill with straight gas.
